Part Alignment
Part Alignment
jonEP2M6
Part Alignment
jonEP2M6
I'm trying to use part alignment on a casting body, we have done this part before and part alignment worked great but when i import the results i get yellow arrows in a lot of places (mostly in the z axis) Can anyone help me with what this means because they don't show as above or below tolerance?
When i import the inspection results there's an error that states "1 surface inspection contains points that could not be projected" I presume this is the problem but not sure on what is causing the issue.
Further information: We are using the casting body to select probing points and the same body is selected when importing the results. (Same method as last time)
Many Thanks, Jon
Richard.stubley
Hi @jonEP2M6,
These are Unprojected points I did quite a long explanation here on what they are and how to deal with them. See post 5
https://forums.autodesk.com/t5/fusion-360-manufacture/part-alignment-workflow-on-a-haas-vmc/td-p/100...
Hope this helps, let me know how you get on.
Richard Stubley
Product Manager - Fusion Mechanical Design
