Part Alignment
- Mute
- Permalink
- Report
I'm trying to use part alignment on a casting body, we have done this part before and part alignment worked great but when i import the results i get yellow arrows in a lot of places (mostly in the z axis) Can anyone help me with what this means because they don't show as above or below tolerance?
When i import the inspection results there's an error that states "1 surface inspection contains points that could not be projected" I presume this is the problem but not sure on what is causing the issue.
Further information: We are using the casting body to select probing points and the same body is selected when importing the results. (Same method as last time)
Many Thanks, Jon
