OKUMA Post Processors
Message 1 of 17
I am looking for 2 seperate post processors, I need one for an Okuma GENOS M560-V with A axis rotary, and one for an Okuma Genos L300-MYW with Y axis, live tooling, sub spindle and mill turn. Has anyone used either of these on Fusion before?
Replies (16)
Message 2 of 17
martha.deans
Hi John,
Unfortunately I'm not familiar with Okuma posts, but I wanted to make sure you knew there is a separate forum specifically for post processors where you might be more likely to find an answer.
Here's the link: http://forums.autodesk.com/t5/post-processors/bd-p/218
Cheers!
Marti Deans
Product Manager, Fusion 360 Manufacturing
Message 3 of 17
I am new here, so i thank you very much
Message 4 of 17
Hello did you ever find good posts for either of those okuma's? I started using fusion 360 and I really like it except that I've had a hard time finding good Okuma posts for it
Message 5 of 17
On the lathe I use mainly the IGF conversational but also add some cad here and there, but on my m560v I did find one I really like, I can forward it to you Monday from work if You like, all I have to do is remove the letter I the program name and remove a null at the last line, then it's good till go, I could probably change that but I look through my code anyways, it's okuma 3and 4 axis .
Message 6 of 17
Thanks that would be great, with most of the posts I've found I spend almost as much time editing code as I do programing it on the cad/cam
Message 7 of 17
steve
Here is the latest beta post I have found. It is getting very close.
https://cam.autodesk.com/hsmposts?p=okuma_lb3000_mill-turn
Message 8 of 17
Thanks Alot I will definitely give this a try
Message 9 of 17
Could you send me the post for the m560v? we have one too and i can't get any other post to work in it with the a axis.
Message 10 of 17
marius_micromet
Hi
I'm also looking for a post-processor for an Okuma GENOS M560-V with a rotating shaft.
If you find something, please post the processor as well.
I want it too.
Message 11 of 17
I was wondering if you could email me the geno's m560v post. Thank you.
Message 12 of 17
KrakenBuilt
Hi John,
Im desperately looking for a post to the m560v. If its something you wouldn't mind sharing.
Message 13 of 17
seth.madore
@KrakenBuilt have you tried the generic Okuma post processor that Autodesk has?
Seth Madore
Message 14 of 17
Here's a good Post
Message 15 of 17
Sorry it didn't attach originally
Message 16 of 17
KrakenBuilt
Thanks Seth, ill tuck this in the back pocket. 🙂
Message 17 of 17
KrakenBuilt
Thank you so much Craig. I really truly appreciate this. 🙂 thank you thank you
