New update making all programs old and new mill off center with 2D contour
When I go to an old program or make a new program. After roughing I do a 2D contour to make a finish pass. When doing a bore it will not mill on center with the hole/bore that I selected. It is not always noticeable on fusion but once I make a part it is obvious. I found that when I change the lead in parameters it will sometimes fix it but I am running programs that it ran fine before. I had just updated fusion yesterday and this is when the problem started. This is ruining parts and costing us money. Most of our parts have already gone through the lathe for roughing, sent out for heat treat then back to the lathe for finishing then to the mill. that is a lot of time and money wasted when fusion is causing this to happen. Anyone know if I can revert back to an older version of fusion? Just back to the last on before I updated yesterday.
