Nesting add on
Nesting add on
bigcol007
Nesting add on
bigcol007
Nesting add on,get the parts to rotate to sheet.
I have allow part rotate on in source component.
If i have the sheet length and width the same ,the parts will nest .
if i have at 8' x4' sheet ,they will not .
The part are not roateing .
the only thing i was think to fix it was change the grain direction.
no luck there.
thanks
          colin
seth.madore
Could you share the file that is behaving like this?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply
Seth Madore
bigcol007
here you go.👍
