Need help with 2D Adaptive Toolpath
j_bergman
j_bergman
I'm trying to run a 2D adaptive tool path, and I can't seem to get the tool path to do I want. It seems to get maybe 90% through, and when it approaches the fillets, it looks like the tool path changes. I want it to take little bites all the way to the end of the part. I thought I was getting the hang of this software, apparently, I'm not.
Thanks!
programming2C78B
Its doing exactly what it should!
if you just want a slot mill, draw a rectangle as your contour selection instead.
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
Oh, it's still taking little bites out of the material, it's just a deceptive look at first glance. The selection tells it that it's open at the large end, so it makes an exit into that space and gives the visual of "large chunks".
Seth Madore
j_bergman
It does look deceiving. I will give it a go in the morning. You inspire confidence...and I need a little at times.
Thanks Again!!!
seth.madore
That's what we're here for!
Seth Madore
