need help - simulation for plasma cutting
michelblouin3
Message 1 of 20
michelblouin3
I try to simulate a sketch for plasma cutting. i  tought i made all is required but cannot make simulation. Thanks
i joint screen prints...2023-01-21 (1).png2023-01-21 (2).png2023-01-21 (3).png2023-01-21 (4).png2023-01-21.png
Accepted solutions (3)
Replies (19)
Message 2 of 20
seth.madore
Hmm.
Could you export and share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 20
michelblouin3
hope you can help...thanks
Message 4 of 20
seth.madore
For some reason, your Kerf Width was set to 1". Go into your tool library and change this field:
Result:
Seth Madore
Message 5 of 20
michelblouin3
nice...but next, i dont have the signs below to start the simulatuion (pause,stop, play,ff,rewind)
Message 6 of 20
seth.madore
Click this
Seth Madore
Message 7 of 20
michelblouin3
the signs under the design...
Message 8 of 20
michelblouin3
I found it...sorry
Thanks for yours replies, it was very helpfull.
Message 9 of 20
michelblouin3
new problem, try to post process, click post process button then click post and got a message telling "NC code failed to post"
Message 10 of 20
seth.madore
I likely won't see your reply until morning, but..
What post processor are you using? It sounds like you might be using one that's not configured properly for a plasma cutter..
Seth Madore
Message 11 of 20
michelblouin3
no problem to wait until morning...
see the picture below.
I cant interprete the errors messages
Message 12 of 20
seth.madore
Can you share that post processor here? I'm not seeing a posting error in your photos, just the JavaScript of your post
Seth Madore
Message 13 of 20
michelblouin3
the post processor picture is for you to see what post processor i use.
the errors picture are what i see when i click the post key in post processing.
Message 14 of 20
seth.madore
They're the same picture though:
Post Processor:
Errors:
Where did you download your post processor from?
Seth Madore
Message 15 of 20
michelblouin3
sorry...that one
Message 16 of 20
seth.madore
That's because you've set your WCS origin to the bottom of the part. It appears that this post processor (which isn't an Autodesk file, btw) does not like that. Set it to the top of the part
Seth Madore
Message 17 of 20
michelblouin3
i down remember exactly where i download the post processsor from...i guess from their web site
Message 18 of 20
michelblouin3
I'll try that...
do you recommend me to use another processor?
Message 19 of 20
seth.madore
If that post processor is giving you proper code, I'd just adjust where I set my WCS and continue on
Seth Madore
Message 20 of 20
michelblouin3
That's what i did and looks ok.
So, i'll go that way to the next step.
Thanks again.
