Need help/explanation of "Groove Suppression" in profile turning?
lethal375
Message 1 of 16
lethal375
How does the groove suppression work?
Trying to prevent the profiling tool from entering o-ring grooves
On the OD roughing and finish profile there is only an option to "Suppress Grooving"
On the ID roughing and finish profile there is an option in the linking to not allow grooving?
Replies (15)
Message 2 of 16
engineguy
@lethal375
See image below for what we have here, it is under the "Cycle and Direction" Tab.
Message 3 of 16
lethal375
Yes I have that option on the ID profiling but not on the OD?
On the OD I have to scroll down to the bottom of the geometry tab where it says Groove Suppression
Message 4 of 16
engineguy
@lethal375
Ah, my apologies, I didn`t read your question properly, to answer, the "Groove Supression" seems to work fine here, I will do a short screencast to show what I have and if I have understood correctly.
I don`t know why you don`t have the same "drop down options" as we have here, that will have to be answered by an Autodesk Employee 🙂 My Build number here is 2.0.14337
Screencast link Here:-
Message 5 of 16
akash.kamoolkar
@lethal375 can you attach your file here so I can look at the issue?
thanks,
Akash Kamoolkar
Software Development Manager
Message 6 of 16
lethal375
When I try to Share it will not let me select "Link"
I can only select "Launch Screencast Recorder"
Message 7 of 16
lethal375
Hope this helps
Message 8 of 16
lethal375
Try this
Message 9 of 16
lethal375
Screen cast
Message 10 of 16
lethal375
Sorry
I can't seem to get anything to work
Message 11 of 16
engineguy
@lethal375
Check your email for a link that you copy and paste into your reply, there are only certain of the higher echelon that are allowed to "embed" a Screencast into a post 🙂
I have done a small Screencast that may be of some help to you, used your uploaded file and just did a Face, a Roughing Profile and a Finish Profile just to show what/how things were selected, hope it is of some use to you 🙂
Screencast link here :-   https://autode.sk/3Ra6ie0
Ooops, apologies, forgot to attach the modified file 🙂
Message 12 of 16
lethal375
Here are yours and mine
Message 13 of 16
akash.kamoolkar
@lethal375 if your "groove suppression" parameter in the geometry tab is checked it overrides the grooving parameter in the passes tab.
Akash Kamoolkar
Message 14 of 16
engineguy
@lethal375
You need to have the "Groove Supression" turned off as in the Screencast and the file I did in order to use the Groove Options in the "Cycle and Direction" area 🙂
Edit:  Ah, too slow here with the post, I see that @akash.kamoolkar has already pointed that out to you 🙂 🙂
Message 15 of 16
lethal375
Ok
Thanks, As usual there was a simple answer
So how does the Groove Suppression face selection work?
Message 16 of 16
akash.kamoolkar
@lethal375 the groove suppression feature was introduced to allow suppressing grooves more flexibly on a more selective basis whereas the "grooving" parameter suppresses all grooves or none. So if you need to suppress individual / multiple grooves you can suppress them by selecting all the faces that bound those grooves and the toolpath will not enter them. you can play around with it and attach your f3d file here if you have any issues.
Akash Kamoolkar
