- Mute
- Permalink
- Report
We recently purchased a 3-axis multicam cnc router. We can use enroute to run the machine fine.
My company has much more experience with fusion and rather use that for cam. The problem seems to be in our tests with cam produced in gcode. The machine is ignoring the feedrates that we have set up in cam.
We have the spindle speed at 18000 rpm
The feed rate will be set at 36in/min
Run the file and the machine will run it at 1000in/min which is it's max for the machine. It will slow for corners but ramps right up to 1000in/min when it can.
Has anyone else encountered this or know of a solution. I'm leaning on the side of user error because we're still learning or even bad posts for the machine.
I've search the forums and turn up no answers.
