Multi-axis programming (DMG MORI CTX 1250 BETA TC)
darko.beretic
darko.beretic
I am trying to make a working post for this machine DMG MORI CTX 1250 BETA TC, where I started with this one: https://cam.autodesk.com/hsmposts?p=dmg_ctx_800_beta_tc&_ga=2.112820803.630596210.1633462953-3393415...
I am totally out of multi-axis programming, especially on Siemens (Sinumerik840D) stations, so first thing I am unable to solve is this...
Lathe is going pretty well, but when I want to mill something tool rotates as it should but gets out of position for like 100mm from workpiece in Z direction which I dont understand why... Picture attached (sorry for my paint skills, tommorow I will try to video my problem)
If there is someone who is aware of this or has any knowledge in multi-axis programming on Sinumerik840D work stations, I would be thankful.
serge.quiblier
Hi @darko.beretic
it's hard to diagnose without any element.
It can be an issue with the TC(...) command used on the Siemens controller.
This is adapting some elements (wcs?, tool offset? based on the b axis orientation)
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
