missing and broken link components in the Assembly file (hybrid)
jblsound1
jblsound1
First issue - component appears in the component browser tree, but not in the modelling window.  All show/hide icons are in the show state through out the browser tree.
Second issue - I have a component that has it's name in RED but is visible in the modelling space.  I believe the red indicates a broken link.  I had this same problem yesterday with this same file with two other components that I was trying to insert into the assembly.  My work around was to save copy as then insert the new saved as component into the assembly.  Today the problem is back with the new saved as version of the component.
Third issue - in the manufacturing space fusion is up to 220 sheets of nesting with nothing on them.  I have to "End Task" and kill the program for it to stop.  the entire model only needs 9 sheets to cut the entire job with a proper nest.
The above issues happen after I was able to process the sheets when I made the initial  nests.  I lost some parts during the milling and another sheet had x-out of bound errors.  All the above issue happen while trying to fix and replace the sheet and parts I had lost during the milling process.
I need some sort of explanation to why and then a how to fix these issues.
I am working with panel goods and nesting all the parts for cabinets.
rosie_lucas1
Hi @jblsound1,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Rosie | Community Manager
