simple slot while using 4th axis
stringm
stringm
Hey,
I am trying to get simple slot down the X axis while the 4TH axis rotates, is this even possible? I know i can use a smaller tool and different tool paths to get what i want but i would like to just use the same size tool as the slot and different step downs.
https://a360.co/4tSagfb
programming2C78B
Very easy to do. See attached
Please click "Accept Solution" if what I wrote solved your issue!
stringm
Thank you so much! I had messed with the 2D contour and i guess didn't spend enough time trying to get it to work.
so simple, thank you!
