Constraining patterns around Z to 3-axis movement using 5-axis config
SerhiiPohorielov
Message 1 of 11
SerhiiPohorielov
Hi everyone,
tldr: pattern around Z rotates C axis instead of rotating the toolpath instances
Added 5th B+C axis trunnion to a 3-axis DNM5700 recently, edited the original machine config from HSM library accordingly, plus added a few functional tweaks from previously used 3-axis PP (also from library).
All the 3-axis and 5-axis functions are performing as expected, except patterns around vertical axis.
I still do a lot of 3-axis work on a stationary zero-point plate stationed beside the trunion, and in a normal condition C axis is parallel to Z.
I have quite a bit of cylindrical parts held in 3-jaw chucks through said zero-point, so the vertical axis of a part also defines XY zero in setup.
When a pattern of some features is created around the same vertical axis, Fusion assumes that the part is also situated exactly at a center of C axis and instead of rotating the toolpath instances themselves, rotates the C axis (which does not carry a part).
Choosing any other axis and/or suitable part feature does not help, Fusion can clearly idenify that my Z axis is collinear to C.
Can anyone point me to a workaround for this? Ideally I would like to be able to use both rotating C axis pattern and a toolpath rotation around arbitrary vertical axis.
Or at least have an option to easily force Fusion to ignore B and C axis.
I can see using separate PP with multiaxis functions disabled as a last resort.
Exact pattern attached, sadly cannot show the part.
Thanks!
Replies (10)
Message 2 of 11
programming2C78B
Does your post dialogue give you these options? Do you use the Z axis line as your circular rotation point or the select dia on the part itself?
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 11
SerhiiPohorielov
Nope, post uses in-built machine configuration, changeable only through .cps file.
I tried defining both setup Z axis and pattern axis in pretty much every combination. It seems to me that Fusion detects their alignment regardless of selected features hierarchy.
Message 4 of 11
euclidmandd
@SerhiiPohorielov
I'm wondering if you ever found a solution to this. I recently updated my postprocessor (Haas NGC UMC 750) and now I'm having this issue. It wasn't an issue on the old post, so I guess I'll just go back to that for now, but it makes me loose a couple other features I liked with the new post.
Message 5 of 11
matty.fuller
Should be easily possible by creating a second machine definition that doesn't have the B/C axes configured. This is the approach we take with our VF2SSYT with TRT210, I choose one machine definitition for working on the trunnion and the other for working on the table.
Message 6 of 11
SerhiiPohorielov
Unfortunately, I did not as of yet. I`m certain that it is possible to trace the logic behind the C axis output using Autodesk plugin for Visual Studio Code, but I have yet to find sufficitent time to do that.
Message 7 of 11
a.laasW8M6T
Hi
Currently you can do this with a post modification(I cant remember exactly where to change it) or By using a 3 axis machine config as @matty.fuller  says.
In the Future you will be able to control this in the pattern itself in Fusion.
I'm not sure exactly when this will be available though
Andrew Laas
Senior Machinist, Scott Automation
Message 8 of 11
euclidmandd
Good to know there's a fix in the pipeline. For now I'm just going to stick with the old post. Most of my programs need 5 axis positioning, so using a 3 axis configuration won't work. in the meantime, if you come across where/how to do that post modification, please let me know.
Have a good one
Message 9 of 11
a.laasW8M6T
@euclidmandd  Pattern rotation preferences are now available in the latest update
See what's new
https://www.autodesk.com/products/fusion-360/blog/april-2026-product-update-whats-new/
Andrew Laas
Message 10 of 11
euclidmandd
@a.laasW8M6T
Wow, good timing! Thanks for pointing that out. I'll give it a shot next time I'm programming something like that.
Message 11 of 11
SerhiiPohorielov
I tried posting rotary pattern with my previous postprocessor using linear preference and it worked, no C-axis output, just planar XY as needed.
Cheers to devs for answering the feedback!
