mach3 turn threading g76
Message 1 of 23
hi i have a lathe run by mach3 turn
the post processors ive tried want to output g code for canned cycle as g78   .. i can produce g32 if i uncheck canned cycle .
i would like g76  canned cycle .
is there anything i can do /buy /change to get this?
regards steve
Replies (22)
Message 21 of 23
thanks
easy when you know how
Message 22 of 23
will_1
Hi @Anonymous ,
Did you have any luck with G76 threading?
Will Watkins
Message 23 of 23
not had time to try it as ive put a new motor in the lathe will have a go on the weekend ..
can you help my startup subscription is about to run out . i re applied a week ago . no confirmation email and no contact  can someone check to see if im in the system
steve
