M140 heidenhein post procesor version43302
werkplaats2Q7LY
Message 1 of 8
werkplaats2Q7LY
hallo
since short we hav a new machine on the shopflor we programa over fusion 360 an post whit the heidenhain  tnc530,620,640
when we try to get it it to the machine there is no M6 to do the tool call in the g code program   and they post generata a M140 code what the machine can not read . can sombody help me so that ther is no M140 any more ? her is also a pic.
Replies (7)
Message 2 of 8
Arun.rs
Hi @werkplaats2Q7LY
You can uncheck the 'Use M140' in NC Program page . Refer below image,
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
Message 3 of 8
engineguy
@werkplaats2Q7LY
Are you looking for something like this ??
 If yes then try the attached PP
Message 4 of 8
a.laasW8M6T
Hi engineguy,
Heidenhain wont let you put an Mcode in the TOOL CALL block, it has to be in a separate block below the tool call
most Heidenhain controlled machines don't actually need an M6 at all which is why its not in the post, but some machine tool builders seem to want to use the M6, maybe to match up with G-code machines for similarity.
Andrew Laas
Senior Machinist, Scott Automation
Message 5 of 8
engineguy
@a.laasW8M6T
Yes, I did know that but I just did the modification as shown for the OP to come back and let us know exactly what his particular control needs, from what I know from a couple of Heidenhain users it can sometimes be worse than Fanuc for big variations from one Machine Tool builder to another for asigning M and G codes to often completely different functions !!!
Message 6 of 8
Arun.rs
Hi @engineguy
May be like picture below can use M6 in Heidenhain controller..not sure, may @werkplaats2Q7LY  can comment on this.
Regards
Arun.RS
Message 7 of 8
engineguy
@Arun.rs
Yes, that may be possible, but I do not think anyone can do more until @werkplaats2Q7LY responds to the suggestions 🙂
Message 8 of 8
werkplaats2Q7LY
he needed a M6 in a line under the tool call i fixxed it whit writing a block under the tool call cycle  and it works so thanks everybody to help !
