Lathe Parametric Programming
britovsekmatic128
Message 1 of 8
britovsekmatic128
i am wondering is there a way to make the CAM for lathes almost automatic?
For example, i would like that the outside roughing toolpath always goes 5mm over the half of the total lenght that i set in the CAD workspace, essentially having a parameter to always offset the half+5mm in the toolpath strategies.
The same for inner roughing and finishing but always going to the BoreDepth value.
So when i change the values in CAD the CAM will update with these values, is it possible and will result in a stable programming procces or if it is even worth it and will i have troubles down the line trying to troubleshoot what went wrong/isn't working?
2nd question: Is there a way to bring in 3d cad models of holders/tools into the tool library?
3rd question: Why are the graphics in my lathe workspace simulation so funky?😬 (Milling works/looks fine)
Many thanks!!!
Replies (7)
Message 2 of 8
ltomuta
1. You cannot access CAD parameters in CAM.
2. You cannot import tool models. There is however a script floating around the interwebs that can read a 3D model and generate the holder geometry out of it.
Message 3 of 8
ltomuta
Here's the link to the script mentioned above. https://www.nyccnc.com/solid-model-to-tool-holder/
Message 4 of 8
britovsekmatic128
I know you can't  access CAD parameters in CAM directly, but since F360 is model aware i think it could posible to set the offset depth(Geometry tab) according a parameter.
Message 5 of 8
ltomuta
As long as the model information exposed to you through an operation's CAM parameters is enough for your needs you can, of course, use it. Here's a half+5mm example
Message 6 of 8
britovsekmatic128
For me it really isn't working. I get the paramaters working but i don't get the desired result and after clicking ok to see the toolpath and going back to editing it i get Failed to evaluate expression in the offset window.
Message 7 of 8
ltomuta
Yes, you are right. It only works once and only if the start offset is 0.
The problem is that such expression is recursive, it uses backHeight_value to calculate the backHeight_offset but once the offset changes then backHeight_value changes as well
Message 8 of 8
ltomuta
So here's an offset expression that does not depend on backHeight_value:
(abs(surfaceZLow)-abs(surfaceZHigh))/2-5
