Invalidated toolpath - "Invalidation due to different value for parameter 'highFeedrateMode' with level 1."
j9lemmon
Message 1 of 9
j9lemmon
I changed the speed of Rapid Retracts to High Speed Feedrate to slow the retract speed. After doing this for all 4 operations, I got an error message similar to this for each operation:
Invalidated: Clear toolpath
Invalidated: Invalidation due to different value for parameter 'highFeedrateMode' with level 1.
Invalidated: Dependency changed: Setup9b-FP&Pusher revAfterRun1
Invalidated: Parent changed
Invalidated: invalidateByLevel
I don't know what "level 1" refers to. Does anyone know?
Thanks.
Replies (8)
Message 2 of 9
I was having the same issue after updating my preferences, it seems that disabling the "confirm generation when already valid" and the "automatically generate toolpath on operation change" under general>manufacture, caused the issue. I checked both of the settings back on and the issue went away.
Message 3 of 9
jonathanBUCVS
I am also getting this error "Invalidated: Invalidation due to different value for parameter 'job_model' with level 10."
The two parameter check boxes mentioned above were checked. Any other ideas? I cannot attach the file (proprietary).
Message 4 of 9
seth.madore
@jonathanBUCVS Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 5 of 9
jonathanBUCVS
@seth.madore  I cannot attach the file in this forum, it is proprietary. Is there a way I can send it directly to you?
I also realized the thread I replied to was not the exact same error, but this was the thread that came up first when I Googled the error message.
Message 6 of 9
seth.madore
Yep, you can email it to me:
seth DOT madore AT autodesk DOT com
Please link this thread in your email so I understand the context (I get a lot of emails during the week and chase down a lot of threads that need solving)
Seth Madore
Message 7 of 9
jonathanBUCVS
sent. thank you
Message 8 of 9
markaudacity
Was there any resolution to this? Having the same problem.
Message 9 of 9
jonathanBUCVS
Seth never responded to my email, so I never got a formal answer. I think I re-did a bunch of toolpaths, either re-chaining them or starting again from scratch but I have not seen this error in the 2 years since, and I do not remember exactly what I did.
