Post Processor issue or user issue?
natedogg4567
Message 1 of 11
natedogg4567
So I recently came across a problem where my drill depth is being changed by what I think should be an unrelated setting. Maybe it is just me IDK. Under the Heights Tab there is a box called feed height. I want to transition from rapid to feed at lets say .2 above the part. So i set that Feed Height Field setting to .2 from Top of part. During maching however my hole is .2 to deep. If i set it back to 0 the hole is the correct depth.
With the Feed Height set at .2 above Top of Part, I get the following
G81 X1.2951 Y-0.75 Z-1.05 R0.2 W0.575 F13.3
With Feed Height set at 0 above Top of Part or Disabled, I get the following
G81 X1.2951 Y-0.75 Z-0.85 R0 W0.575 F13.3.
Im bothered that the Z depth is changing by .2, the R value I can understand as it is going to .2 above the part. But I dont think that the ending Z value should change based on the Feed Height location. It should still have an overall depth of X-.85 ( Top of hole is at -.75 with a .1 deep spot drill) but with me giving the tool some clearance over the part, it is going way to deep as the next operation is tapping. Am i correct that this is a post processor issue or does this look correct.
This is the newest version of the vickers.cps postprocessor.
thanks
Replies (10)
Message 2 of 11
a.laasW8M6T
Hi
the way the post is outputting the z depth appears to be Incremental from the feed height rather than absolute coordinates
This is quite possibly correct for the Acramatic controller but I don't have a manual to confirm.
I would check the manual for the G83 cycle to see what its says about the z depth.
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 11
natedogg4567
I will look and see what it says
Message 4 of 11
natedogg4567
So according to line 2 it is absolute mode regardless of setting. But line 4 says it introduces a gauge height of .1 automatically. But my issue has to do with the R value. Any idea's ?
Message 5 of 11
a.laasW8M6T
Hi
This section here seems to me to confirm that the Z is from the R plane(incremental)
So the post is correct according to the manual.
Are you getting incorrect results at the machine?
Andrew Laas
Message 6 of 11
natedogg4567
Yes the drill and spot drill is going to deep, if i set the Feed Height to .2 and try to spot a hole .05 deep, the spot drill goes .25 deep.
Message 7 of 11
natedogg4567
So that means that the post is being output as incremental and the machine is using it as absolute?
Message 8 of 11
a.laasW8M6T
I'm not 100% sure
Ive changed this post zo it just outputs straight z coords in absolute
try it very carefully just cutting air and watch the z display as its running to see if its correct.
Andrew Laas
Message 9 of 11
natedogg4567
Ok. I will see what happens. Thank you.
Message 10 of 11
natedogg4567
Deleted
Message 11 of 11
natedogg4567
Post works Perfectly. Thanks for your help
