In need of a post processor
david_pribisJFTSD
david_pribisJFTSD
Community Visitor
Community Visitor
Hi there,
We are a currently looking at making the switch to fusion from Rhino CAM. The main issue we have is the lack of a post processor for our machines.
We have one machine that is built by iCAM, which was a small CNC company based out of Hamilton, NZ, which has since gone under.
I've attached a sample G-code, and the post that we currently use with Rhino CAM.
What's the best way to go about acquiring a post? And if that's not an option what would the best starting point be for customizing a post? I've tried the Autodesk WinCnC post, but it seems way off.
Any help is greatly appreciated!
a.laasW8M6T
Hi
The G code doesn't really look all that special very basic stripped down G-code, looks like G71 is just metric mode and there are no home retracts in the code.
Theres also no G43
You can modify posts relatively easily but it requires a bit of knowledge of how they work.
Cadpro in NZ is a good place to get a post made if you don't want to attempt it yourself.
Ive had a go with the Rs274 post
Make sure you have the settings like this:
Im not 100% sure if it will work with the G43 as your code doesn't have it but the rhino post does show G43 in it.
Andrew Laas
Senior Machinist, Scott Automation
marcus.toepke
david_pribisJFTSD
Community Visitor
Community Visitor
Thanks @a.laasW8M6T,
I did find Cadpro, might have to be the move for us. I'll definitely give your post a go, thank you. I'm comfortable doing a few basic tweaks with posts, but I don't really have the knowledge to change much.
Unfortunately Marcus, I am the little nerd at the office, but I just don't have enough time 😞
marcus.toepke
So the solution is clear!
You need a Back to the Future - Flux Capacitor
https://www.youtube.com/watch?v=VcZe8_RZO8c 🔥😎
