![IMG_3659[1].JPG IMG_3659[1].JPG](https://forums.autodesk.com/t5/image/serverpage/image-id/727349i45E12EF4C1981531/image-size/large?v=v2&px=999)
Thank you both for your replies. I set up my 1942 Brown & Sharpe and cut the appropriate leads. Took some time since it has been quite awhile since I have done that type of work. Even with .002" spindle run out, the finish was better than what Fusion generated.
I don't know why when I hit reply, I cannot include your quote to answer specifically? It used to be when I hit reply it automatically included the persons post that I was replying to?
Daniel,
Thank you for taking the time to show me that. It is funny, when you mentioned surface inspection, I spent some time googling to try and find out what you were referring to. I had no idea "curvature map analysis" existed, nor would I have thought to use it. Unfortunately I have to fall back on my "I'm just a dumb hillbilly". When I create a surface, I assumed that Fusion created a surface. That is the extent of my knowledge. In 5+ years of using Solidworks for all my CAD/CAM work, I never once ran into this issue. I guess this is the point where I learn and understand why Fusion costs what it does comparative to SolidWorks?
I will save your suggestions for next time to try out. I prefer to run bull nose instead of ball cutters primarily for speed and surface finish. I can run bull nose at much higher feeds and speeds and typically they result in better finishes depending on the type of work. There is plenty of angle in this part, that a ball would work well, and I will try that on my next batch of parts.
I appreciate you taking the time to show these ideas and help me understand better. Your right in that I do not have the time to play. As mentioned, I am pretty ignorant when it comes to things like fusion. Whether with past Autodesk products (primarily autocad), Solid works, mastercam, etc... I never spent any time that I remember with "workarounds" or tweaking part geometry trying to get them to a machinable state. Because of this, I now keep an excel spreadsheet that is my "solidworks" fund. Whenever I lose money on a job because of Fusion, I record that loss. I'm a machinist, not a computer scientist. I suppose it is my ignorance, but I shouldn't need to do a "curvature map analysis" or a "mesh conversion" to be able to machine the parts. This is all several steps backwards in the world of machining. Perhaps I should take a step back, am I doing something incorrect with my modeling? I see folks online machining far more complex, far more intricate items with Fusion, and none of this tweaking or working around is necessary. Perhaps someday this will make sense. Until then... I'll keep adding to my Solidworks fund.
Mark,
Thank you for taking the time to make this video for me. Is this a normal process for you with the models that you machine? This mesh issue, would this explain why I see part variance and issues with Fusion code vs Mastercam?
To answer/address some of your other commentary:
the sample part is a piece of the part that I made. Because the way Fusion handles stock, I have to model my stock, select the model body as stock, then simulate. That carried over to this sample when I stripped away the rest of it, sorry for the confusion.
In the past, on almost every curved surface that I machined, I would extend the surfaces to allow for Fusion to (in my opinion) correctly machine the curved surfaces. Someone on this forum made me a great little video, such as the one you made for mesh conversion, and I wrote a little "process" sheet for myself on how to do that. At some point recently Fusion did another random shuffle and icon change and I no longer can find any of the buttons/functions that I used to use to do this. As far as I can tell, that function is no longer available, because my old models/programs lost those features.
Specifically in regards to the mesh conversion, as I asked above, is this something that you do on a regular basis? Should I be doing this as a standard part of my "work flow"? I guess what I am asking is, how do I know when I am supposed to do this?
I am also curious what other effects does this have? What is the balance to making these changes? If I make this change to the parent part, how else will it, could it, effect the part? Or is it more a matter of effecting the part size/computer usage?
Thanks again to both of you for your help.
