How to turn on and off displaying material?
TomaszAdamF
Message 1 of 8
TomaszAdamF
Hey
I usually use "Shaded with visible edges only" style. When the material of the object I'm building is smooth, like steel, Fusion displays the image very smoothly. But I work in wood, and when the material of the object is 3d wood, Fusion significantly slows down.
I'm sure the display speed depends on both the processor and the graphics card, but maybe someone knows the simple way to "turn off" and "turn on" the display of materials other than turning on the wireframe style or removing the material to work and re-applying it to the visualization.
Replies (7)
Message 2 of 8
LibertyMachine
I'm not aware of any current advantage to having actual material depicted. Outside of visual accuracy, just use the simplest thing for your computer?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 8
Did you ever receive an answer on how to do this?  I'm about to post the same question.
I have materials for rendering - but for modeling - I'm happier with the pastels that are standard.
I'd love to toggle material views on and off.
Ethan
Message 4 of 8
Or in reality what I want is to have 1 set of colors in Model view - and then my actual materials applied for renders.
TYIA
Message 5 of 8
TomaszAdamF
The only method I know is switching "Visual Style" to "Wireframe with
Visible Edges Only". However, this is not the same as shaded gray when
all materials are standard steel. So I'm still using the materials that
are given for rendering, which slows down the work and reduces the
readability of the drawing.
Message 6 of 8
Thanks for the response.
I wish there was a way to toggle this. Worth a feature request?
Ethan
Message 7 of 8
ben_harveyN2G5R
Shift + N Toggle Component Color Cycling.
Message 8 of 8
programming2C78B
2,932 days for you to not give the correct answer?
Please click "Accept Solution" if what I wrote solved your issue!
