how to turn an undercut?
mikeNCNTL
mikeNCNTL
I am trying to turn an undercut, shown in the image below. I changed the orientation of a 35 degree tool, so the tool should be able to get in there. I just can't seem to make Fusion do it?
File also attached
a.laasW8M6T
It works if you turn the spun profile preview off:
Andrew Laas
Senior Machinist, Scott Automation
mikeNCNTL
I have turned this off and I still do not get the desired result?
mikeNCNTL
So, I figured out what you did. I had to set to axial grooving
a.laasW8M6T
sorry i missed that you only had "allow radial grooving" on.
You need allow axial, or allow axial and radial
Andrew Laas
