how to set Points or positions of Leads and Transitions can be set to mill a half workpiece.
witawat57
witawat57
Hello all,
i have question
how to set Points or positions of Leads and Transitions can be set to mill a half workpiece. ?
On the green line, how can we change direction?
engineguy
@witawat57
You can Edit your Sketch so that you only have a Half Circle that you can then select by holding down the Alt key and selecting just the curve that is to be machined.
For the Leads/Transitions set them to 0 except the Linear distance so that you have a straight move into the material, also, under the Linking tab enable the "Keep Tool Down" option. Modified file attached, have look through the settings, hope this helps 🙂
This toolpath gets you image two!This toolpath gets you image two!
Or, you can try using the settings as in the second 2D Contour and have it Helix into the material as below 🙂
witawat57
Thankyou very much
