Running a few Mazak Quick Turn lathes with milling capabilities, this specific machine has a Fusion640t control.
Trying to do a simple engraving on the outer diameter of a part but having problems with the C-axis not choosing the shortest path.
As you can see in the image attached, the machine just finished the row above going to C-161.738 and the next order of operations is to go to C-161.588, a difference in 0.15 degrees, yet as you can see on the buffer window the next move the machine will do is C-359.789, so spinning the wrong way around the part.
It does this on every C-axis row in the program, spinning back and forth instead of taking the shortest path.
Anyone seen this before?
We're using the standard Autodesk post processor which can be found here: https://cam.autodesk.com/posts/post.php?name=mazak%20quick%20turn%20250-msy
Here is some of the code: https://p.ip.fi/7DGe
