How do you machine this ellipse spiral?
I have watched tutorials that show how to wrap a 2d adaptive path onto a cylinder using patches, but that only works with a single consistent diameter like a shaft.  I am trying to create a 4th axis path that spirals down to different diameters.  Also, the spiral has an ellipse profile.
Any suggestions would be appreciated.
Marco.Takx
Hi @Anonymous,
If the bottom of the spiral path doesn't have to be perfectly flat you can, for example, make a Surface Thicken offset of Half the diameter of your mill.
Then use Trace to select the edge of that surface.
At the moment compensation on Tracing isn't working.
See attachment of an example.
If this isn't what you look for please share your model and explain what you like to want.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
I do need a flat bottom on the spiral.  Just using xyz would give me a cupped bottom surface.  I believe using 4 axis should give me the results I am looking for.  The photo shows what continuous cutting I am expecting in the Z and X as the rotary turns.
Marco.Takx
I haven’t try it yet but I know there are some 4th axis functions within the Beta environment in some operations on the Passes tab.
Idon’t know if a solution is there yet.
Give it a try.
http://www.manufacturinglounge.com/hsm-beta-mode-hsmwork-inventor-hsm-fusion/
Marco Takx
daniel_lyall
@Anonymous or @Anonymous can you post the model To do this Go to File -> Export and save as a .F3D Archive File and attach it to your next post
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Here is the file...
daniel_lyall
The WCS in your setup is missing the X-axis selection.
When you set the toolpath you have to give it a center of rotation or be able to set an offset for the center of rotation.
The wrap toolpaths need a round references, sometimes it will work with a nonround shape.
I am having ago to see if I can get a toolpath to stick, so far no dices.
Daniel Lyall
The Big Boss
Mach3 User
