Help with 3d contour
MJK_Performance
Message 1 of 16
MJK_Performance
im trying to use 3d contour to finish the outside of this part so i can use multi axis tilting, but i cant get it to cut the vertical walls. i have tried a few things with no luck, help pleeeeease!
Replies (15)
Message 2 of 16
MJK_Performance
Message 3 of 16
LibertyMachine
Not gonna lie. This thing is really kicking my computers arse
Think it might be good to call in the professionals: @xander.luciano@cj.abraham any ideas?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 4 of 16
MJK_Performance
haha, i got it to cut the vertical walls with the touch surface option (how did i over look that) the onlt problem now is with the multi axis tilting, only wants to cut at 40 degrees 😞
Message 5 of 16
Steinwerks
I have this so far:
Yes, it's using Outside Boundary, and Touch Surface instead of Avoid. I guess part of the question is how far you want it tilting?
@LibertyMachine Ah those mobile chips are awesome until they aren't, right? To be fair I think this took about three to four solid minutes to calculate on my old FX8350 Black Edition. I need to upgrade before my webinar I think...
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 6 of 16
MJK_Performance
*internal screaming* HOW DID YOU GET THAT!?!?!
Message 7 of 16
Steinwerks
"Chill, Winston!" Smiley LOL
I think the only things I changed were on the Geometry tab:
Neal Stein
Find me on:
Message 8 of 16
MJK_Performance
of course it all works perfectly for me know *sigh i guess programming at 6am while your sick is just asking for trouble. Thanks for all the help guys, you will forever be my heros.
Message 9 of 16
Steinwerks
I just realized that screenshot didn't capture the surface selections so I'm adding one here that does. Don't know how that happened. I just added every surface that existed at the level of or above the height definition in the toolpath.
And @MJK_Performance no problem! The more issues you have, the more I learn too Smiley Wink
Neal Stein
Find me on:
Message 10 of 16
Steinwerks
@MJK_Performance I've attached the one I programmed. Maybe I clicked something I didn't realize (it's happened before and then I spend half an hour figuring it out).
Neal Stein
Find me on:
Message 11 of 16
k6ls
not sure what you're trying to do, or if I have the right surfaces selected, but I was able to get something accomplished with 3D Adaptive clearing.
first thing I did was start a new setup and assign a new WCS for what I assumed was the 'outside' of this part.
see uploaded file.
not saying it's 'the answer', but something to work with, play around a bit and see what works for you
Message 12 of 16
LibertyMachine
@k6ls, thanks for jumping in. but, this was a double post that "should" have been removed from the forums... /smacks Admin upside the head
Seth Madore
Message 13 of 16
Discussion_Admin
smacking fully deserved Smiley Embarassed a little behind today. I merged the two post into one.
Discussion_Admin
Message 14 of 16
Steinwerks
Discussion_Admin
Aww did that kill my solution too? Or did @MJK_Performance kill it? Smiley Sad
Neal Stein
Find me on:
Message 15 of 16
MJK_Performance
i think i might have, ill give it back just for fun 😉
Message 16 of 16
Steinwerks
Aww! Does this mean no beers when in close vicinity then? Smiley Very Happy
Neal Stein
Find me on:
