Help! Special tool for inside turning bore
Good day, everyone.
I have some issue, with the creation of a comertial tool, and the programing of a special feature.
The choice of tool is from Sandvik, (A12S-SDUCR 2-ERX), with the insert DCMT 07 02 08-PM 4335.
It is possible to create a new tool with the selected configuration?
I´ve getting troubles to configure the virtual tool, and generate the desired path.
Here you´ll find some images to illustrate the doubth:
seth.madore
Unfortunately, I don't believe that such a tool and turning strategy is currently supported in Fusion. Let me check with the turning team and get you a definite answer though
No, it's not possible, sorry. Confirmed with the turning team.
Seth Madore
seth.madore
That said;
If you turn off the holder and play with the orientation, you should be able to accomplish this.
The tool orientation or set-up angle would need to be used to adjust the seated angle of insert since the holder is no longer there. Set-up preferably should be used.  If it's like a 55 degree insert the set-up angle is 90 degree's with an orientation of -27.5 for the seat angle of the holder + -3 which is the tool lead angle, so -30.5,
Seth Madore
Ketherton21
your best bet may be disabling the "holder" in your setup and configuring the insert alone to the corresponding angles.
edit wow I didnt even see your 2nd post Seth bwahaha.
Seems to be the desired solution, I'll be reporting the results!Solution.png
