Helical ramping issue
Message 1 of 12
This video will demonstrate the issue.
Replies (11)
Message 2 of 12
Laurens-3DTechDraw
Is your model selected in the setup?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 12
It wasn't, now it is, however the issue still persists. I really thought you got it there.
Edit, I would also like to add that any value below stock top 0 causes this toolpath genertion failure.
Message 4 of 12
Steinwerks
Can you share the part at all?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 5 of 12
not at this time.
Message 6 of 12
jeff.walters
If you can’t share it here can you export it to a .f3d and send it to [email protected]?
Jeff Walters
Senior Support Engineer, CAM
Message 7 of 12
I will see about that later tonight. My stock is actually .005" thinner than I put in the simulation, after the change I can't any toolpath. Very strange.
Message 8 of 12
Sent.
Also, thank you for this excellent product. The availibility of software as powerful as this freely to the public is a benefit to mankind.
Message 9 of 12
jeff.walters
The problem is your pocket is only .02 from the top of the part and you have your fine stepdown set to .03125 so the system is saying the step is too small to cut.
Jeff Walters
Message 10 of 12
Awesome thanks
Message 11 of 12
Hey, are you aware of any add on, or whatever to aid in debugging of toolpaths? Generally, the generation failure warning is a bit lackluster. Sometimes it will lead me to my problem, but most times I just get nothing.
Message 12 of 12
jeff.walters
This has been brought up to development many times. They are working one it
Jeff Walters
