Haas ST20Y in Machine library ?
JamesCipolloni7683
Message 1 of 37
JamesCipolloni7683
looking to program my ST20Y in Fusion,   can't  find the machine ?  is there an alteritive?
Replies (36)
Message 2 of 37
seth.madore
At the moment, there are no lathes or turn/mill machines in the library. Why? Fusion does not yet support Machine Simulation of these machines, but we're working on it 🙂
Seth Madore
Message 3 of 37
JamesCipolloni7683
I'm finding more and more that Autodesk seems to focus on the newer or latest technologies and less on what shops are actually using. a small amount of shops are using the latest and greatest. I wish Autodesk would work on improving the "everyday tasks" we use in Fusions Cam.  Master Cam, Gibbs Cam and others have had for 20 plus years.
Message 4 of 37
seth.madore
Such as...? Machine simulation for lathes is long overdue, and we recognize that shortcoming and are working at rectifying it with urgency.
Seth Madore
Message 5 of 37
JamesCipolloni7683
Simulation is fine, I don't sit in front of a computer all day, This is just a tool to get my machines to make parts my customer need, the less time I spend here the more time I get to make parts. Improve the everyday tasks. that the most important thing to me., I will try to get a short list together.
Message 6 of 37
JamesCipolloni7683
AUTODESK HAVE A MILL TURN POST YET FOR HAAS ST20? I see a generic mill-turn machine in setup but what post would I use?
Message 7 of 37
seth.madore
Yep, we got em:
There are no machine configurations yet, since Machine Simulation does not yet support lathes or Turn/Mill machines.
Seth Madore
Message 8 of 37
JamesCipolloni7683
Thanks Seth appreciate your efforts , Ok got them but you can't use them correct?
Jim
Message 9 of 37
seth.madore
Oh, you most certainly CAN use the post processors to program a turn/mill lathe! You just can't use Machine Simulation (just regular simulation)
Seth Madore
Message 10 of 37
JamesCipolloni7683
Where is the post ? I'm not finding it?
Message 11 of 37
JamesCipolloni7683
Seth,  is it the same post for Inventor /HSM as 360 Fusion?
Message 12 of 37
seth.madore
Inventor/HSM and Fusion use the same post processor. You can find the ST-20Y Post Processor HERE
Download it to your computer and link the location of the post in your  Post Library:
Seth Madore
Message 13 of 37
JamesCipolloni7683
What am I missing here?  It fails when I run the post see below , is the manual nc correct?
Message 14 of 37
seth.madore
Does it succeed if you don't include those Manual NC commands?
Seth Madore
Message 15 of 37
JamesCipolloni7683
the failure is similar but not the same
Are these setting correct?
Message 16 of 37
seth.madore
No idea. Could you share your solid model here? I'd ask you for your Fusion file, but you're using Inventor. Has your company decided against going with Fusion 360 for your design and manufacture needs?
Seth Madore
Message 17 of 37
JamesCipolloni7683
Seth, well it's my company I can use both, I prefer Inventor only because I'm more experience with it can I import it. into Fusion?
Message 18 of 37
seth.madore
Give this a read
Seth Madore
Message 19 of 37
JamesCipolloni7683
SETH, DID YOU GET PRIVATE MESSAGE ?
Message 20 of 37
seth.madore
I did, and will review when I have a moment (kinda swamped in other matters at the moment)
Seth Madore
