Haas Post processor a axis problem.
turningHU8CX
Observer Observer
turningHU8CX
Observer
Observer
We have Haas VF4SS with 4th axis, with our Haas next generation control post processor Fusion wouldn't post process program when "has A-Axis rotary" is set into reversed and C axis is rotatting the wrong way at the moment.
this is what error page says
Any help would be grat !
AchimN
Hi @turningHU8CX ,
it looks like you are trying to postprocess with a machine configuration AND have the "Has A-Axis rotary" property selected at the same time. This results in the conflict that you are trying to post with two machine configurations and it then fails.
You can only use one method, so you either must set your "Has A-Axis rotary" property to "No" or deselect your machine configuration.
Achim.N
Principal Technology Consultant
programming2C78B
The error code says it completely correct.
Also FYI there's a setting on the controller to reverse the A axis if you don't want to mess with it in the Post.
Please click "Accept Solution" if what I wrote solved your issue!
programming2C78B
https://www.haascnc.com/service/troubleshooting-and-how-to/how-to/reverse-rotary-direction-setup---n...
turningHU8CX
Observer
Observer
This method worked. Thank you very much
