HAAS NGC post property blank after reposting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having an issue when posting my programs that made me crash my rotary twice now from me not checking my post properties every time I post.
I have edited the default "hasAAxis" value as "reversed" to suit my primary setup. If I need to post a program without an A axis I'll just toggle the property in the post dialog to "off". Then if I go back to posting a program with an A axis, I'll either select "reversed" or just click "reset to post default", and post. Whenever I need to repost that same program, even if immediately after resetting to defaults, the "hasAAaxis" property is blank. As a result, it posts rotary moves in the opposite direction that I need and crashes my part or fixture if I don't catch this glitch...
Attached is a screenshot of the post dialog after resetting to defaults the last time I posted, along with the edit I did to change the default that I need. Hopefully someone can chime in on if I missed something, what's going on or if someone has had similar issues.
Edit to add: I've encountered this with multiple versions of the HAAS NGC post provided in the Autodesk post library so I don't believe it could be an issue with that..
Andres
