G54 work coordinate - best practice
a.sooriasegaram
a.sooriasegaram
I've come across a few video tutorials now where the recommendation is to edit the NC file and remove G54 coordination system from the G code - instead inserting G,0 Z,10 for example to guarantee the cutter raises up high enough to clear stock before traversing in the x & y planes. I'm not familiar with G55 coordination but I usually always start from bottom left corner of the stock at the stock's top height.  Only once have I encountered the tooling not elevating to the correct clearance before traversing and scratching the surface.
Would appreciate your suggestions on this.
Thank you
seth.madore
G54, G55 are what's called "work offsets". They tell the controller where your part is located on your table and allow for multiple jobs or Setups to be run consecutively. Some controllers (the lower end hobby grade) don't have functionality that allows for this.
What machine and controller do you have?
Seth Madore
programming2C78B
If you home the machine properly this isn't needed...never heard of this in over 10 years
Please click "Accept Solution" if what I wrote solved your issue!
a.sooriasegaram
Hi Seth,
Thanks for your help. At work we're using a Colchester Clausing 4VSQ MillPWR G2 with the accurite millPWR G2 Console.
It's a bit intimidating to be honest! My own hobbyist machine is a Shapeoko XL with software from Carbide 3D.
Ahilan
brad_francola
@seth.madore This is a funky control from the looks of the Manual.
brad_francola
brad_francola
After looking at the manual for this control, I understand what you were saying in your initial comment.  It appears the control does not recognize G54 (or any traditional WCS command).
