Fusion Tool Orientation Error in CNC
dhanush9LY6JA
dhanush9LY6JA
I have issues using the tool orientation option provided under geometry for 5 axis CNC machining. The workoffset seems to be shifted quiet randomly when I run the code on the 5 axis CNC. The toolpath generated and post processor work well and also the simulation looks fine, but on the CNC it starts machining few 100mm above the defined local workoffset. Note: Without using the tool orientation, if I define any other complex 5 axis moves, I have no issues running on the CNC. Thanks
I am using the Sinumerik 840 post from fusion
atdemo2019
IS THAT ORIGIN IS CORRECT??
