fusion 360 wrapping function for Mach3 in MM only
daniel_lyall
Mentor Mentor
Message 1 of 63
daniel_lyall
Here is a new tool for everyone (Mach3 so far) this was done by @HughesTooling He did the post processor changes and the .f3d file I just asked for it, all credit for this goes to Mark he the Man with the getup and go to do this.
attached is the post processor and demo file for wrapping Y axis to A this post processor can be used to convert X or Y axis to A you just need to make sure radius correction is set to half diameter in the file the diameter is 50 so the correction is 25, and make sure the axis of rotation is set in tool paths under config in Mach3.
I have not tested this on a machine yet also your X, Y, Z and A axis zero's have to be set first before running it there are some small changes still to be done it will be reposted when done but it works and is useable.
any question ask here.
Edited by Request
Discussion_Admin
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Replies (62)
Message 61 of 63
daniel_lyall
@HughesTooling all good now
Daniel Lyall
The Big Boss
Mach3 User
Message 62 of 63
i use my smart phone to take the pic
Message 63 of 63
daniel_lyall
@Anonymous I have it sorted now I missed one step you have to set the radius in the post before posting.
the screen shots for the setup in Mach3 are correct.
I have done a screencast to show what to do and the cam file and the .f3d to go with the screencast is attached.
the radius is half the Cir or 1/2 the width in the setup
I will be redoing the youtube vids for this.
Daniel Lyall
The Big Boss
Mach3 User
