Using a body as stock
quincyVTN2Z
Message 1 of 10
quincyVTN2Z
We have a 6mm plate that we use as a positioning tool. Now we have to modify it, by milling some edges of.
The red body in the screenshot below is the existing part. The Blue body is the correct part. How do I go about this in Fusion 360?
Replies (9)
Message 2 of 10
Steinwerks
In your Setup you'll want to go to the Stock tab and use the pull-down. Go to "From Solid Body" and select it, which I believe can be done from the CAD tree or directly selecting the model.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 10
quincyVTN2Z
I understand how to select the other body as a stock, but when I set up a 2D pocket toolpath it will create a toolpath for the entire contour, as shown below. I want it to just mill the remaing material.
Message 4 of 10
Steinwerks
I believe that 2D operations won't look at the stock model. You can either create a sketch and use it as your Stock Contours in the Geometry tab, or you could try a 3D Pocket Clearing and constrain it to the new pocket, and check Rest Machining From Setup Stock. Several ways to get around this, and there may be more that I'm not thinking of right now.
If you can export the part as a .F3D file and share it here I'd be glad to take a stab at it.
Neal Stein
Find me on:
Message 5 of 10
quincyVTN2Z
Hi, thanks for your answer. I attached the model as a .f3d
If you could take a look, that would be great!
Message 6 of 10
Steinwerks
Not a problem.  How about this?
Neal Stein
Find me on:
Message 7 of 10
quincyVTN2Z
Great work!
This is exactly what we need!
Just to be clear, u used 3D pocket clearing for this?
Message 8 of 10
Steinwerks
Yes, that's what I used in this example. Personally I would use Adaptive Clearing though, and follow up with a 2D Contour to finish. You'll have to try some things out to find what works best for your parts and machine(s), but I'm glad this was helpful.
Neal Stein
Find me on:
Message 9 of 10
Steinwerks
The file is attached to the post too, so take a look at the geometry selections in the setup and toolpath. I didn't bother changing anything about passes or linking so they're stock.
Neal Stein
Find me on:
Message 10 of 10
HughesTooling
You can do it with 2d. You need to select the stock like this. File attached
Mark
Mark Hughes
Owner, Hughes Tooling
