fusion 360 wrapping function for Mach3 in MM only
daniel_lyall
Mentor Mentor
Message 1 of 63
daniel_lyall
Here is a new tool for everyone (Mach3 so far) this was done by @HughesTooling He did the post processor changes and the .f3d file I just asked for it, all credit for this goes to Mark he the Man with the getup and go to do this.
attached is the post processor and demo file for wrapping Y axis to A this post processor can be used to convert X or Y axis to A you just need to make sure radius correction is set to half diameter in the file the diameter is 50 so the correction is 25, and make sure the axis of rotation is set in tool paths under config in Mach3.
I have not tested this on a machine yet also your X, Y, Z and A axis zero's have to be set first before running it there are some small changes still to be done it will be reposted when done but it works and is useable.
any question ask here.
Edited by Request
Discussion_Admin
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Replies (62)
Message 21 of 63
daniel_lyall
for now do it in MM you can just ball **** Mach3 and make it the inch size just pretend it's in metric say 3 inch make it 3 mm that sort of thing, I will dig in see what I can find is wrong. unless Pi can be done in metric or inch
Daniel Lyall
The Big Boss
Mach3 User
Message 22 of 63
daniel_lyall
@Anonymous you have the wrong post
Daniel Lyall
The Big Boss
Mach3 User
Message 23 of 63
is there an updated post processor in the google drive thats linked?
Message 24 of 63
daniel_lyall
@Anonymous you have IJ set wrong second pick it should be Inc, and you have lathe setting set in toolpath take them off, then it should be good.
post your M3 profile.
Daniel Lyall
The Big Boss
Mach3 User
Message 25 of 63
Where do i locate IJ to change it to inc?
Message 26 of 63
daniel_lyall
Daniel Lyall
The Big Boss
Mach3 User
Message 27 of 63
Ok ive changed all those settings and used the new post processor you linked. Im still getting the big blue circle in toolpath.
Message 28 of 63
daniel_lyall
try this file
Daniel Lyall
The Big Boss
Mach3 User
Message 29 of 63
Same thing. I linked a pic. Im running Version R3.043.062 of mach3. Im guessing im having the issues within mach3
Message 30 of 63
daniel_lyall
post your profile .txt it in your M3 folder
Daniel Lyall
The Big Boss
Mach3 User
Message 31 of 63
i apologize for my ignorance. I do not know how to do that.
Message 32 of 63
daniel_lyall
it's the profile name the one you select when you start up Mach3 on the computer the default one is Mach3Mill it's a XML doc.
Daniel Lyall
The Big Boss
Mach3 User
Message 33 of 63
ok here is mine. I have a profile.txt in there already.
Message 34 of 63
daniel_lyall
That's what I wont
Daniel Lyall
The Big Boss
Mach3 User
Message 35 of 63
Here is my profile.txt. There isnt really anything in there. That may be the problem lol
Message 36 of 63
daniel_lyall
ESSG0704 is your profile it is what you click to start mach from the splash screen it will be in the M3 folder. it will have ESSG0704 XML document
Daniel Lyall
The Big Boss
Mach3 User
Message 37 of 63
sorry about that here is my xml.
Message 38 of 63
daniel_lyall
@Anonymous is the xml you posted the one you run your machine with
Daniel Lyall
The Big Boss
Mach3 User
Message 39 of 63
Yes essg0704 is my main profile I use to machine
Message 40 of 63
daniel_lyall
@Anonymous Right screen shot's of what you need to do
once you have settings set like above you should get the same out come as the pick below using the posted code.
now for some reason you only get a half circle in inch, Metric is fine I will have to dig in a find the problem.
also I would suggest you check all your other setting's and look through the Mach 3 manual tp
Daniel Lyall
The Big Boss
Mach3 User
