Fusion 360 Post-Processing Issue with Multiple Offsets (G55/G56) After Update
micahjPFZVT
Message 1 of 9
micahjPFZVT
Hi All,
I'm encountering a critical post-processing issue in Fusion 360 after a recent update, and I'd greatly appreciate your assistance.
Our company recently acquired a new Avid CNC machine, and we're using Fusion 360 for programming. While I'm relatively new to manufacturing in Fusion, I've been successfully generating programs for our machine, which utilize two offsets (G55 and G56) for different sections of the program.
Prior to last week's Fusion 360 update, my programs would post-process without any issues. However, since the update, any program attempting to use both G55 and G56 offsets fails during post-processing. Interestingly, if I post-process operations using only G55 or only G56, they succeed. I've confirmed that my machine in Fusion is set up for multiple offsets, and even attempts to re-post previously working files now result in failure.
The post-processor log consistently shows the following errors:
Warning: -Attention- Property 'Safe Retracts' is set to 'Clearance Height'.
Ensure the clearance height will clear the part and or fixtures.
Raise the Z-axis to a safe height before starting the program.
Error: Tool length compensation is not active.
Error at line: 2051 (avid cnc.cps)
Error in operation: 'Parallel3'
Failed while processing onSection() for record 21470.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, July 30, 2025 2:00:20 PM
Post processing failed.
Regarding the warnings, my "Safe Retracts" settings appear to be configured correctly (screenshot attached).
The "Error: Tool length compensation is not active" is the primary concern. My tool definitions seem correct (screenshots attached), and notably, it's the same tool used across all three operations within both G55 and G56 offsets. The log references "Error at line: 2051 (avid cnc.cps)" and mentions operation 'Parallel3', but if I remove that specific operation, the error simply shifts to the next one in the sequence.
I've attached a sample of the failing G-code (as a text file) and the complete post-processor log for your review.
Any guidance or support you can offer to resolve this issue would be greatly appreciated.
Thank you,
Micah Johnson
Replies (8)
Message 2 of 9
seth.madore
Could you share a sample file that would generate this issue?
Are you using the "Avid" post processor from our library?
Seth Madore
Message 3 of 9
a.laasW8M6T
Hi
I can replicate this,
It seems to be a bug introduced in the post 6 days ago.(possibly to do with the addition of TCP stuff to the post which seems redundant for that machine)
If you use the previous version it works fine.
See attached.
Andrew Laas
Senior Machinist, Scott Automation
Message 4 of 9
seth.madore
Ok, so a post issue. I'll alert the team
Seth Madore
Message 5 of 9
micahjPFZVT
Here is a link to a Calibration version file that I use.
https://a360.co/45baDXd
Message 6 of 9
micahjPFZVT
Would i just need to move the attached document to "C:\Users\Mjohnson\AppData\Local\Autodesk\Autodesk Fusion 360\CAM\cache\posts" in order to roll back the changes?
Message 7 of 9
a.laasW8M6T
Hi
The easiest way to do this is to go to the post library and import it to either your local or cloud folder
Then you can select it from your local/cloud folder when you go to post process
Andrew Laas
Message 8 of 9
AchimN
Hello @micahjPFZVT ,
Thank you for your feedback.
The issue you mentioned was indeed introduced with the latest post update.
I have already fixed it, and the updated posts will be available next Monday.
Apologize for any inconvenience this may have caused!
Achim.N
Principal Technology Consultant
Message 9 of 9
micahjPFZVT
No, worries, thank you for helping me with a temporary solution as well as fixing the overarching issue so quickly.
