Hi @joeystreet_wst
Thanks for posting! I've seen a few of these issues before and usually this is indicative of something in the toolpath making generation take a long time for legitimate reasons. I believe this is occurring on your end - the Adaptive toolpath does continue to generate and I bet it will complete if given the necessary time (which is sometimes overnight in these situations).
This is because of the way Adaptive toolpaths are calculated - because Adaptive toolpaths look for paths with constant tool engagement, they are computationally more intensive than some other options like Pocket. This is discussed in this article on CAM Performance and toolpath generation - please give it a read.
With your toolpath partway generated, we can see the tool is looking for curved paths through all the small contours. 63 chains is a large selection for any toolpath, but the problems with this are amplified when we are trying to force adaptive paths through small channels .
That is a lot of very small, arced cuts to clear out some pretty straightforward pocket geometry. While it would be great if Adaptive could generate quickly here, we'd still get a huge amount of code to run at the machine with this toolpath.
I think that Pocket is a better operation here. If you right click the "stuck" Adaptive operation and create a derived 2D Pocket operation, the toolpath will generate very quickly and result in a toolpath with faster machining times, less code, and nice straight cuts instead of the arcs.
Now, if you let the Adaptive sit overnight and it does not generate, feel free to let me know and we'll log a bug. With that said, I think that this cut would be better approached with a Pocket strategy than Adaptive. I'll leave it calculating over the Thanksgiving break on my end as well so I can compare the machining times and NC file sizes when I return next week.
Paul Clauss
Product Support Specialist
