Is anyone else having this problem? It seems fusion is rounding any of the numerical fields to the nearest thousandth.
If I punch in 0.0004", hit OK, then reopen the tool path it's at zero.
if I punch in 0.0005", hit OK, then reopen the tool path it's at 0.001"
It's with any numerical field in the tool path too, if I try to add a start/end extension to a open chain 2D contour it rounds it as well.
I tried inputting scientific notation too and that still gets rounded.
I've tried to use the tool wear comp in the tool path and that just gets rounded.
The only way I can get around this is to modify my model.
I've even opened up an old program and it rounds off my values in those too where I used to be able to input values less than a thousandth.
Did I somehow change a setting or was this with one of the last updates?
This is a detrimental change as I just scrapped one of my parts thinking I was taking off 0.0005" but was really taking off 0.001"
