Error in default LinuxCNC Post (not setting G0/G1 after G80)
Cederb
Message 1 of 14
Cederb
When generating a drill cycle in Fusion 360, LinuxCNC suddenly stops and gives me a "cannot use axis values without a g code that uses them" error.
The code looks like this:
(3004_DRILL_3.5MM)
(T2 D=3.5 CR=0. TAPER=118DEG - ZMIN=-4.052 - DRILL)
G90 G94 G91.1 G40 G49 G17
G21
(DRILL3)
M5
M9
T2 M6
S2000 M3
G54
M9
G0 X108.02 Y4.3
Z25.
G98 G81 X108.02 Y4.3 Z-3.052 R25. F10.
G80
X68.8 Y17.884 Z25.
Z24.
G81 X68.8 Y17.884 Z-4.052 R24. F10.
Y42.884
G80
Z25.
G81 X108.02 Y67.38 Z-3.052 R25. F10.
X4.3
Y4.3
G80
Z15.
M9
M30
The problem is that it cancels the G81 cycle with the G80 command and then tries to move the axis without setting the correct G0/G1 for movement, so LinuxCNC does not know what to do with the axis values it is fed.
Replies (13)
Message 2 of 14
dave.anderson
You might have better luck on this by posting in the CAM Post Forum if you have not:
https://camforum.autodesk.com/index.php?board=3.0
Dave Anderson
Sr. Support Engineer– CAM
Autodesk, Inc.
Message 3 of 14
Steinwerks
Just as a note, standard G-code does not require the setting of G0 after a canned cycle if the modal feed code before it was G0. It should default to G0 (or G1 if it was in feedrate as opposed to rapid). What machine is this? Can you see if there's a setting that changes the modal operation?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 14
Have your post been edited or is this the stock one that comes with Fusion?
Looking at the code, whenever a G80 occurs the gMotionModal is reset.  This means that for the next move a G0-G3 should be generated.
function onCycleEnd() {
  if (!cycleExpanded) {
    writeBlock(gCycleModal.format(80));
    gMotionModal.reset();
There is only one place in the post that I see where an axis move is created without a gMotionModal first occuring and that is within a cycle after the first move...
Are you able to share your model here so this can be recreated to better help troubleshoot?
Dave
Message 5 of 14
calexpavel
I know the post is old, but i have the same problem and i was wondering what solution have you found.
Message 6 of 14
daniel_lyall
details please
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 14
calexpavel
It wasn't adding a g0 or g1 command after g80, but i have added
at the end of
onCycleEnd()
function and now it works.
Thanks!
Message 8 of 14
G1, G2, G3, G0 are modal commands, in effect until changed to another G code in same group.
G80 cancels canned cycle, not last G0 or any of the other codes.
So I am curious, what's the point in having redundant code? is this unique to Mach3 or just "preference" in the way you want your code to look?
I have come across all possible formats that mean nothing to machine but define someones style and preference.
Things like repeated G1 on each line along the cutting path,.......or Z0.00, still no more and no less then Z0 just more clutter.
Message 9 of 14
calexpavel
I have very little knowledge about g code, but i had this error before adding that line on my post code, and now i don't  get it anymore, so i guess it wanted G0 or G1 again. I have no idea...WhatsApp Image 2019-06-20 at 20.00.10.jpeg
Message 10 of 14
Well, that's interesting, some controllers have different rules, I have zero experience with oddball equipment, except for Anilam, still trying to forget everything I learn about it.
Message 11 of 14
seth.madore
@Anonymous wrote:
..except for Anilam, still trying to forget everything I learn about it.
Good luck with that. It's been 20 years since I ran a 3200M control and I can see the menus and dialog boxes like it was yesterday...
Seth Madore
Message 12 of 14
Your ignorance index is too low, focus on something else just as dumb then mix it all together and,....... PUF...... gone.
Message 13 of 14
daniel_lyall
Linux can be a bit funny like that.
Daniel Lyall
The Big Boss
Mach3 User
Message 14 of 14
dylantrinh
Observer
Observer
Bump to an old topic but this worked for me also. Thank you or the help. I added it to the last line of "function onCycleEnd()"
at the end of
onCycleEnd()
Thanks!
