Message 1 of 8
Engraving: remove material left over in the middle
01:09 PM
- Mute
- Permalink
- Report
Hello!
I am engraving a pattern in wood, the surfaces to be engraved are partially larger than the v-bit. This results in material being left over in the center of the respective surfaces. What is the best approach to get rid of those? Using a regular end mill won't work, es the edges are not sharp as compared to the v-bit. 3D adaptive clearing also does not work, as the nice sharp edges created by engravig are not present.
The v-bit hast a top diameter of 4mm, bottom diameter of 0.2mm and a 30° angle.
The pictures show the geometry I'm using to create the engraving and the simulated material. I highlighted some of the material I want to remove in red.
Thanks in advance and best regards.
