I’m modeling an 8” x 13” carved panel for a 17th century chest (Fine Woodworking, Feb. 2011), but I had problems with the “manufacture” module. So I extracted a 3” x 3” area to play with.
I sketched the empty area, extruded the area to create a plank, added a decal, sketched the detail, extruded the carved areas down, and deleted the decal. That “design” result looked fine to my inexperienced eye.
Moving to the manufacture module, I tried both the 2D adaptive clearing and the 2D pocket process but neither worked as I expected them to. For each, I used the sequence of 1/4”, 1/8”, and 1/16” bits to reach into the narrow arms, but not all of the areas were cut. I combined the adaptive clearing to rough the cavity and the pocket to finish it but still without complete success.
I suppressed the pocket toolpaths. Using just the adaptive clearing, some areas in the arm were not cut at all (even though the 1/8” bit fit into the areas using the pocket process), and many edges were not cut to reduce the “stock to leave” as I cut closer to the final dimension on the smaller bits.
I suppressed the adaptive clearing toolpaths and un-suppressed the pocket toolpaths. Using just the pocket process, some areas were again not cut at all and the successive toolpaths seemed to ignore the reducing the "stock to leave" settings.
My 3rd attempt retained the adaptive clearing with the 1/4” and 1/8” bits and the pocket process with the 1/8” and 1/16” bits. But there were still uncut areas and edges that had not had the stock cut to final dimensions.
Is this behavior normal, or am I misusing the tools?
I would sincerely appreciate any comments, criticisms, or suggestions that you can offer.
Very respectfully,
Larry
