Engraving errors
Engraving errors
marklev3
Message 1 of 73
Engraving errors
marklev3
Gday all
Have been Vcarving using ENGRAVE without any problems for 2 years, however since the last upgrade (sic) of Fusion and using existing previous sketches, the tool does not handle curved edges at all.    It goes to the correct depth but does not enter ( by raising the toolpath ) in any corner.    My sketches have a mixture of straight sided pockets  - straight sided and curved edges and curved edges pockets.
Have been using as a hobbyist but decided to purchased a month just to see if a full blown FUSION 360 would overcome the problem - NO.    Loaded Fusion 3 times - new computer and fusion loaded all to no avail.
Methinks there is a bug in the new version but someone might know a work around.
Would appreciate any help.
Replies (72)
Message 41 of 73
gabrielvuelmar
Indeed seems that Autodesk either doesn't have people that can handle this issue, doesn't want to solve or it's a feature that doesn't bring enough revenue to the brand.
I'm here with all to celebrate 4 months of this issue.
This answer probably gonna be marked as a solution, as previously, but we are still begging for a solution.
Toolpath generated today:
See ya all in 2 months to celebrate half year.
Message 42 of 73
felix.colman
Tengo el mismo problema y la misma necesidad de respuesta desde MAYO.
Nunca vi un problema sostenerse por tanto tiempo, me pregunto si realmente se estará evolucionando en este asunto. Creo que sería bueno tener alguna novedad, siempre con el debido respeto y deseo de éxito al equipo encargado de encontrar la solución.
Saludos a todos.
Message 43 of 73
seth.madore
All,
I believe this issue has been fixed, and you should see some improvement in the next release.
This is what I'm getting with the Insider Preview (a program anyone can sign up for)
Seth Madore
Message 44 of 73
engineguy
@seth.madore
Yep 🙂 Works here also with the Insider 🙂
Message 45 of 73
felix.colman
Buenas tardes,
Aquí adjunto un ejemplo de que aún no funciona la herramienta con "ARCOS NO TANGENTES".
Se debe tener en cuenta que el desarrollo en el ámbito del dibujo conceptual, especialmente en el diseño de logotipos, es muy frecuente que se utilicen formas simples con intersecciones, como lo son los arcos y rectas, que generan una "intersección" que no es visible actualmente por el sistema de "Grabado".
Con "Splines" no hay problema aparente.
Saludos y mi respeto de siempre.
iMac 27 Late 2013
OSx: Catalina 10.15.7
Message 46 of 73
seth.madore
@felix.colman
Por favor, comparta su archivo aquí.
El arreglo que mostré arriba todavía no está presente en la versión de producción de Fusion, pero estará disponible relativamente pronto
Seth Madore
Message 47 of 73
felix.colman
Aquí adjunto el archivo, Seth.
Quedo atento a las novedades y agradezco tu comunicación.
Saludos cordiales.
Message 48 of 73
garywatson00
I’m sorry but I don’t speak Spanish! I wish I did but these posts are meaningless to me.
Message 49 of 73
marklev3
I don’t speak Spanish as well but all I do is open the Spanish conversation
and get google to translate the file and VOLA it’s translated for me.
I installed GOOGLE TRANSLATION and it worked no problems.
If you don’t have it installed ask your 6 year old grandson to do it -
these kids are genius at doing this!!!!
- Please type your reply above this line -##
Message 50 of 73
seth.madore
Esto es lo que verás después de la próxima actualización:
The above was translated with the app "DeepL". In English: "This is what you'll see after the next update"
Seth Madore
Message 51 of 73
felix.colman
Muchas gracias, Seth.
Espero con ansias la actualización.
Mis respetos y cordial saludo.
Message 52 of 73
felix.colman
Así mismo, Marklev.
También, yo abría las conversaciones con el traductor del foro, pero últimamente no me funciona la utilidad con el navegador "Safari", creo que desde "Google chrome" no hay problema.
Yo entiendo bien el inglés técnico, entiendo todo lo que escriben aquí, pero aún me cuesta redactar en su idioma, y no quiero ofenderlos con faltas ortográficas. Tengo muchos amigos de habla inglesa, algunos son sus compatriotas obviamente, y realmente es muy gratificante conversar en su idioma, más si se trata de dibujo técnico, fabricación digital, innovación o desarrollo tecnológico.
Algo que recomiendo es el seguir aprendiendo, seguir estudiando, yo lo hago con una app de idiomas, y creo que a día de hoy, cualquiera de ellas es genial para seguir avanzando intelectualmente.
Se aproxima el Autodesk University, ciertamente. ¡Estoy ansioso por las conferencias!
Saludos y fuerte abrazo.
Message 53 of 73
marklev3
Gday U lot
I'm sorry to inform you that you have not solved the problem. I
waited for the last revision ( that's 3 revisions from when first
detected ) and the problem still exists.
But keep trying please as this facility (ENGRAVE) is most important.
Message 54 of 73
seth.madore
@marklev3 that's because the "fix" hasn't been released to users yet. It's coming, though, and relatively soon 😉
Seth Madore
Message 55 of 73
felix.colman
Problema resuelto.
Con la actualización realizada el día de ayer puedo verificar que este problema se ha solucionado.
Gracias @seth.madore por tu acompañamiento en todo este tiempo.
Saludos cordiales a todos.
Message 56 of 73
seth.madore
Yep, this problem should be solved in the latest update. If everyone in this thread could check their files to see if everything is "as it should be", that would be great. If there are still issues, I will reopen the (or create new) ticket(s)
Seth Madore
Message 57 of 73
gabrielvuelmar
Hello @seth.madore.
This is the drawing that used to work 100% in the past, after the last update it does seems like it's working perfect again.
Want to say a huge thanks, last days have been very busy but I submited for Insider program also. Gonna have a check as soon as got some time.
Sorry for the harsh comments sometimes, but it was a topic that took some time to solve and who uses it constant suffered a bit.
Thanks for your effort as well as all the team.
Best Regards.
Message 58 of 73
marklev3
I have just downloaded the latest update and am delighted that,   After spending all day using and try to break ENGRAVE, I have failed,    It worked without a failure and seemed to me to much faster.
Well done Team.
Message 59 of 73
johnnyfive
Most of my files work again, which is fantastic! I'm still having issues with this super simple engrave. I'm getting straight lines rather than a curved toolpath.
I redrew it and reprogrammed it in a new part, just in case there was something funky left in the original part file and had the same results. If I roll it back to a previous version from a few months ago, it does work, but if I make any changes at all to the part and have to regenerate, it breaks again.
Thank you for the help!
Message 60 of 73
seth.madore
@johnnyfive please share that file so I have something to demonstrate on the ticket.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
