EMC2 post processor (LinuxCNC)
michaell1978
Message 1 of 10
michaell1978
I use Linuxcnc to control the lathe during the work with Fusion360 when forming the control program two questions arose:
1. when trying to create a control program with g thread content, the code is not generated and an error opening the file pops up, after changing the post processor to fanuc or deleting the thread cutting process, everything works.
2. when generating the g code with the EMC2 post-processor, you have to make adjustments in the program, after each tool change, change G54 to G43.
Replies (9)
Message 2 of 10
Boopathi_Sivakumar
hi @michaell1978
Linux CNC post processor only supports for Threading cycle which is (G76), Probably you didn't check the use cycle in the passes tab like the attached image here then it will work
For the 2 question the post processor can be tweaked if you have wanted but for my understanding
G54 is the coordinate system and G43 is tool offset for linux why you want change it and even If G43 comes then there should be H to mention the height offset
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
Message 3 of 10
michaell1978
good day
As for the G code: I use a machine with an 8-position turret, see photo. Linux cnc uses the tool binding table; compensation length parameters are set in it. According to the document for Linuxcnc, the program writes an empty G 43 code.
G43 enables tool length compensation. G43 changes subsequent motions by offsetting the axis coordinates by the length of the offset. G43 does not cause any motion. The next time a compensated axis is moved, that axis’s endpoint is the compensated location.
G43 without an H word uses the currently loaded tool from the last Tn M6.
G43 Hn uses the offset for tool n.
Note:
G43 H0 is a little special. Its behavior is different on random tool changer machines and nonrandom tool changer machines (see the Tool Changers section). On nonrandom tool changer machines, G43 H0 applies the TLO of the tool currently in the spindle, or a TLO of 0 if no tool is in the spindle. On random tool changer machines, G43 H0 applies the TLO of the tool T0 defined in the tool table file (or causes an error if T0 is not defined in the tool table).
about the thread you were right it all worked.
Thanks a lot for the help, I will try by car.
So that it generates G43 after changing the tool, what needs to be done ....
Message 4 of 10
michaell1978
Добрый день,
я могу сообщить о пробной работе.
Fosion 360 удалось получить G-код, но он оказался неверным, и Linuxcnc не понял его. Мне пришлось редактировать его в соответствии с инструкциями в Linuxcnc.
исправленный текст:
G76 P2 Z-30 I-0,4 J0,4 K2,178 Q29 L0
Насколько я понимаю, это проблема постпроцессора, и я не знаю, что делать дальше.
Message 5 of 10
michaell1978
report
Message 6 of 10
michaell1978
доклад 2
Message 7 of 10
michaell1978
отчет
Message 8 of 10
Boopathi_Sivakumar
@michaell1978
The given post is the generic one for your needs the post needs to be customized.
Let me try to give you solution but i am going out of station for next two days,
attach the model file here which you have used to create a program
File>Export>.F3d and reattach to this thread
Boopathi Sivakumar
www.usamcadsoft.in
Message 9 of 10
michaell1978
Спасибо за вашу поддержку
Message 10 of 10
michaell1978
рабочий файл проверен на машине
Please pay attention to the changes received after editing.
