Doosan Mill/Turn post issues
Jessie.Vaineohurst
Jessie.Vaineohurst
Hello all,
I'm having a heck of a time figuring out how to get this to post properly. I keep getting the following failure log
Machine is a Puma V8300m. I do not have a y axis, so I edited the post to disable y axis.
I'll attach my post file, as well as the f3d.
Any recommendations on different tool paths or strategies are more than welcome.
Thanks all.
Information: Configuration: DN Solutions (Doosan) Mill/Turn with Fanuc 0i/31i control
Information: Vendor: DN Solutions (Doosan)
Information: Posting intermediate data to 'D:\Documents\Fusion 360\NC Programs\VTL Test\1001.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Tuesday, June 4, 2024 12:19:07 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 5.140.1
Configuration path: C:/Users/Jessie/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/doosan mill-turn fanuc.cps
Include paths: C:/Users/Jessie/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Tuesday, June 4, 2024 12:17:21 AM
Output path: D:\Documents\Fusion 360\NC Programs\VTL Test\1001.nc
Checksum of intermediate NC data: a261809cd8e4ba970e3fa26c03de9a78
Checksum of configuration: 9801e51d93d8b07befa9cea450ccc479
Legal: Copyright (C) 2012-2024 by Autodesk, Inc.
Generated by: Fusion CAM 2.0.19426
Error: Y-axis motion is not possible without a Y-axis for operation "2D Adaptive2".
Error at line: 2637
Error in operation: '2D Adaptive2'
Failed while processing onSection() for record 434.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, June 4, 2024 12:19:07 AM
Post processing failed.
a.laasW8M6T
Hi
That type of toolpath unfortunately requires a Y axis to machine in that orientation(using a radial tool)
You can mill using and Axial tool and the XZC mode  but you would need a much longer tool.
Do you have the Manufacturing Extension? if so you could use rotary pocket to rough out and Geodesic to finish with a 1/2" ballnose
See attached file
Andrew Laas
Senior Machinist, Scott Automation
Jessie.Vaineohurst
I don’t have the machining extension.
Is there a path the would allow me to mill the square using an endmill constantly feeding down in Z, moving in and out in X while following the contour in C?
I haven’t been able to figure out what path to use to do something like that.
a.laasW8M6T
Hi
Yes there is but you would need the Extension to do it
The geodesic path can do it with a ball nose, like what I attached but you would also turn on Spiral
You can do it with Flow, Blend, Steep and shallow too, using a Square or Bullnose(Geodesic only allows Ballnose/lollipop), there's a few tricks to get these to work in 4 axis only
But again you need the extension
Andrew Laas
a.laasW8M6T
Oh and Rotary parallel too, it has a spiral mode, that should have been the first one I mentioned haha
Andrew Laas
Jessie.Vaineohurst
Looks like I’m gonna be talking with the powers that be to get the machining extension.
thanks!!
