When you select the surface Fusion can see 2 open edges so it clears the whole face. What you'll notice when you select the closed profile is it doesn't clean the outer corner and will only just clean the 2 open edges. To do this properly you should either make a sketch or use a 3d op. 2d ops are not stock aware so in this case 3d will do a better job. All comes down to use the right tool for the job.
Also @engineguy your selection of 2 profiles is not the correct way to create a boundary, see start of screen cast.
The rest of the screencast shows the difference between a 2d and 3d toolpath. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
