Disrespect from Morph Toolpath?
ilirmartini
ilirmartini
Morph toolpath refuses to comply and does not machine continuously from left to right. It skips areas then comes back to finish those areas. If I select "both ways" it will machine very nicely from left to right but I am machining a shallow angle and need it to machine "one-way" and "uphill" in which case it skips areas. Has anyone encountered this problem?
I attached the file if anyone is interested. Thank you.
a.laasW8M6T
I very rarely use Morph, In fact I don't think I've ever actually machined a part with it.
I have seen that behavior before when looking at other peoples programs but am not sure why it does it.
May I suggest using Blend Or Geodesic set to Blend mode instead.
I think Blend Gives the best results here
See attached file
Andrew Laas
Senior Machinist, Scott Automation
ilirmartini
You are absolutely correct, Blend is a much more respectful finishing strategy than Morph. It machined from left to right and uphill very efficiently.
Thank you for turning me onto Blend and I greatly appreciate your help!
oleg.tikhomirov
Hi @ilirmartini
Thank you for the feedback. I've created CAM-65216 to investigate and fix the issue in Morph strategy.
Oleg Tikhomirov
Software Engineer
