- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Morph toolpath refuses to comply and does not machine continuously from left to right. It skips areas then comes back to finish those areas. If I select "both ways" it will machine very nicely from left to right but I am machining a shallow angle and need it to machine "one-way" and "uphill" in which case it skips areas. Has anyone encountered this problem?
I attached the file if anyone is interested. Thank you.
