Cutting a contour centered on a curve
10:00 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a way to generate a contour toolpath that is centered or "right on top" of a curve?
Within 2D Contour, I only see options for right/left... which makes a toolpath that is offset by the tool's radius away from the original curve. The workaround I have found is to set the tool diameter to something very low, such as 0.00001". However, then the 3D stock simulation is not accurate. I figured maybe I am missing something obvious, thanks in advance for any advice 🙂
Thank you!
