Cutting a contour centered on a curve
Is there a way to generate a contour toolpath that is centered or "right on top" of a curve?
Within 2D Contour, I only see options for right/left... which makes a toolpath that is offset by the tool's radius away from the original curve. The workaround I have found is to set the tool diameter to something very low, such as 0.00001". However, then the 3D stock simulation is not accurate. I figured maybe I am missing something obvious, thanks in advance for any advice 🙂
Thank you!
seth.madore
Seth Madore
Thanks for the response!
Interesting, I guess this is better because you don't have to fake the tool size!
Still kind of a hack / hoop to jump through though, don't you think?
CustomCodeCNC
I am having the same issue. When I turn compensation off like you showed in this post, the tool still stays to the left of the curve, not on top of it. Not sure why...
seth.madore
@CustomCodeCNC could you share your file and indicate which toolpath is causing this issue? You aren't giving a lot of information to go on..
Seth Madore
CustomCodeCNC
Hi Seth,
Yes, sorry for being so brief. As it turns out, as I was thinking about your response and my reply, I figured out what the problem was!
While I did have compensation turned off, I had used "Selected Contour(s)" for the Bottom Height:
This selection offsets the selected contour whether or not you have compensation turned on or not.
Toolpath is offset to the right of the geometry:
I then picked "Selection" and picked the face that I was cutting on with a negative offset, and the center of the tool stayed on the curve like I wanted.
Toolpath is on the geometry:
Cheers, and thank you for your response!
kind regards,
Dave
seth.madore
That sounds like a bug, could you share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
